Long Life Plasma Consumables,Discount For GOFABCNC Table Owners
AVORTEC CONSUMABLES
Hi guys,
We carry different size long life PT80 PTM80 IPT80 IPTM80 plasma consumables please check AVORTEC.MYSHOPIFY.COM
Here are some tips for your plasma torch and consumables:
0.9 tip cuts sheet metal,thin metals. Adjust air pressure accordingly till the tip stops whistling.
1.0 tip good for 1/16” to 1/4” metal.
1.1 tip good for 1/8” to 3/8” metal.
1.2 tip good for 3/8” to 5/8” metal.
1.3 tip good for 1/2” to 1” and better or thicker. Adjust air pressure accordingly.
For PT80 IPT80 torch drag tips, which allows direct metal contact for the PT80 IPT80 torches without shorting out the torch or the plasma cut machine. Please check PT80 PTM80 IPT80 IPTM80, Drag tip kits.
Please make sure your swirl ring is assembled in between inner and outer tips in a right way.
Discount For GOFABCNC Table Owners,please use code "GOFABCNC5",get 5% off your comsumables order.(Valid through 12-31-2020).
Or give us a call, 877-640-3131.
Thanks!
Vicky
Thanks!
Vicky
Re: Long Life Plasma Consumables,Discount For GOFABCNC Table Owners
Yea..These are Awesome Consumables..No need to look anywhere else..Very happy with my Puchases from Jeff !
