FUSION 360
Made by Autodesk, this is the best option for working with DXF files.
bern18462
FUSION 360
Post by bern18462 » Tue Jul 09, 2019 2:35 am
does anyone use fusion 360 to make parts and g code to work with the go fab table software?... i cant get it to export a g code file or image to the tablet for it to be able to read. i dont like inkscape because i cant define a circle at 3" or a perfect circle with it.. maybe im stupid but i cant get it to work for the life of me. any help is appreciated thanks
brennon
rstuart
Re: FUSION 360
Post by rstuart » Thu Jul 25, 2019 12:31 am
Yep I do I use the Hypertherm post processing to make a .nc file works great. Do a google search for post processing with fusion 360 and a vid will come up. I will see if I can send a link
GregSmith
Re: FUSION 360
Post by GregSmith » Mon Sep 09, 2019 5:13 am
rstuart wrote: Thu Jul 25, 2019 12:31 am Yep I do I use the Hypertherm post processing to make a .nc file works great. Do a google search for post processing with fusion 360 and a vid will come up. I will see if I can send a link
I cannot get fusion360 to work at all. I tried all the post processors, even hypertherm's. I use f360 with my Tormach cnc milling machine, no problem. Won't work for me. Best it does is pull up the image in the tablet, then the tablet does nothing after that. deleted and reloaded tablet and table software, no luck. The only program that I see works with gofab is inkscape.
