cutting on both sides of a line
abzwardwell
I have an svg that was created by tracing a part from a pdf using the draw Bezier curves and straight lines tool. The picture is then deleted, a 3/4" bolt hole is added at the top then made a path. The issue is that path to gcode makes a path on the inside of the tracing and the outside of the tracing. It cuts the lines twice once on the inside and once on the outside. The bolt hole is only cut once.
Any ideas? Just need it to cut on the line not outside and inside.
