Accelerated Version 4.79 and UP Problems
Re: Accelerated Version 4.79 and UP Problems
I understand and I apologize if I sounded rude. Just frustrated because my 4.78 was doing wonderful then randomly stopped waiting for ArcOk. Then when I upgraded to 4.81 the ArcOk problem was gone and the dragging/no thc problem started.Go Fab CNC wrote: Tue Feb 02, 2021 5:28 pmWe’re looking in to any and all problems and fixing them as we go.Cody wrote: Tue Feb 02, 2021 4:56 pm Are y'all just monitoring this problem or have y'all looked into the 5 other people posting problems with 4.79+ on here?
We’ve Released:
4.79
4.80
4.81
And intend to Release 4.82 today.
I do them directly. I plug the tablet into my computer and instantly transfer them. Have also tried sending them in my email and then downloading them on the tablet, same result.elopez wrote: Tue Feb 02, 2021 4:53 pmDo you have the files directly on your tablet, or are you opening them from google drive?chademling94 wrote: Mon Feb 01, 2021 3:12 pm Android Version 6.0 (newest one available on this tablet) and model T1045HPN if that helps any.
Go Fab CNC
- Site Admin
4.82 is on the Updates Page. I don’t think it’s on Google Play yet though.
I don’t think anything with the Files has been addressed in 4.82, but THC and Z Axis has been addressed.
Tweaked the Z Diagnostics System to respond better, but also added the option to turn it OFF if it causes any problems. The option to turn it ON/OFF is in the Settings under Table Settings->ArcOK/THC
4.83
Table crash, and tablet crashed?
After power cycling tablet, Table can be reconnected, but will just continue to freeze tablet software.
-Table was 1/2" off deck.
-After power cycling, table needed to be homed.
-XY took off without Z being up.
-After hitting stop, xy stopped but Z went up.
It looked like when it froze, there was the "cannot start cut/torch fault" that blipped up, but seemed to instantly dissapear, or go to background, and was unable to see it, or select the buttons. I believe that when it happened/froze up, it was stuck on that input waiting for me to select what to do, but because screen was gone, I couldnt select anything. It was almost instant. Gofab app was unresponsive. Could not recover. app stop alarm came up from android os, and i clicked a button to stop it.
Thoughts?
Please/thanks,
Scott
Thoughts?
Please/thanks,
Scott
G2_Fabworks
running 4.82 on my tablet. This thc stuff is getting ridiculous. every single cut line it starts, goes about a half inch, then raises up with the plasma still firing and continues tracing the cutpath, just with the torch all the way up at the top of it's travel. If I pause the cut, manually back it up to where it decided to piss off, and restart, it may or may not descend to the sheet before taking off again. If it doesn't go down, it also doesn't fire- just starts operating in the x/y axis and leaves the z topped out. The only time it doesn't do this pattern of insanity is when it decides instead that it just wants to shove my torch through the sheet- it dragged so hard once that it popped the entire z carriage off the guides and bent the torch standoffs in the process. This is borderline unusable at this point just from the unreliability if nothing else. Another fun new thing it does is when i finally get it to start running, it'll go for awhile and then pop up an error message that the thc voltage is too low and says it could be a loose wire in the cnc cable or on the thc board. seems to clear when i wiggle the wires going into the thc board. Going back to 4.79, that one was at least workable.
just installed 4.85, when I try to turn off Auto discovery off it crashes app. If I hit pause button, torch raises, when i hit play it doesnt fire plasma, it runs program from raised torch position or it tries to resume but get the message taking too long to find surface. Keeps losing communication, keeps cutting but you cant pause or anything.
Brent
Brent
Go Fab CNC
- Site Admin
If you’re getting the Cutting Voltage Error that says there may be a Loose Wire and it goes away when you mess with the CNC Cable, then you probably have a genuine issue with your CNC Cable like the App is telling you. 4.79 doesn’t have the ability to diagnose that issue, but it doesn’t mean it’s not still there. It just means 4.79 will respond to the Low Cutting Voltage and Raise the Torch, or Dive the Torch depending on what’s happening with the Signal coming through the CNC Cable.G2_Fabworks wrote: Sat Mar 27, 2021 7:11 pm running 4.82 on my tablet. This thc stuff is getting ridiculous. every single cut line it starts, goes about a half inch, then raises up with the plasma still firing and continues tracing the cutpath, just with the torch all the way up at the top of it's travel. If I pause the cut, manually back it up to where it decided to piss off, and restart, it may or may not descend to the sheet before taking off again. If it doesn't go down, it also doesn't fire- just starts operating in the x/y axis and leaves the z topped out. The only time it doesn't do this pattern of insanity is when it decides instead that it just wants to shove my torch through the sheet- it dragged so hard once that it popped the entire z carriage off the guides and bent the torch standoffs in the process. This is borderline unusable at this point just from the unreliability if nothing else. Another fun new thing it does is when i finally get it to start running, it'll go for awhile and then pop up an error message that the thc voltage is too low and says it could be a loose wire in the cnc cable or on the thc board. seems to clear when i wiggle the wires going into the thc board. Going back to 4.79, that one was at least workable.
Go Fab CNC
- Site Admin
I have a fix for the Pausing/Resuming issue. You’ll have to send me the File to figure out why Parts Discovery is Crashing. I’m assuming the Communication issue is related to the Pause issue.irontexasfab wrote: Wed Apr 07, 2021 9:44 pm just installed 4.85, when I try to turn off Auto discovery off it crashes app. If I hit pause button, torch raises, when i hit play it doesnt fire plasma, it runs program from raised torch position or it tries to resume but get the message taking too long to find surface. Keeps losing communication, keeps cutting but you cant pause or anything.
Brent
I’ll have a fix in the next 2 Weeks. We have another Update coming out that has more Features and these fixes will be a part of it.
