Accelerated Version 4.79 and UP Problems
Newest Version of the Go Fab CNC Accelerated Software
Post any Issues or Requests related to the Accelerated Software here.
Site Admin
Post by Go Fab CNC » Mon Jan 18, 2021 3:25 am
This is the place to post any issues you're experiencing with the newest release of the Go Fab CNC Accelerated Software Version 4.79.
We are actively monitoring this Forum and will roll out necessary changes ASAP.
Yarbermarine& fab
Re: Accelerated Version 4.79 and UP Problems
Post by Yarbermarine& fab » Tue Jan 19, 2021 7:03 pm
Unable to communicate with table
Post by Randy » Wed Jan 20, 2021 12:46 am
Keep your plasmas off well you update lol it will fire when updating table and then fire again when Finishing. Another is when you first load up you can't change size till you change out size of metal then you can change size. Other than that she is moving well no drag yet so that's good 👌
Colyevo
Post by Colyevo » Sat Jan 23, 2021 12:32 am
THC still not working correctly, tips are new, good ground, but torch keeps raising after a couple of inches of cut! This has been an issue with all versions of software on my table!
It has also sporadically deleted a couple of separate files sent to table, after toggling with the settings a couple of times, when returning to cut, the file will be have disappeared!
andrewt87
Post by andrewt87 » Sat Jan 23, 2021 10:07 pm
Every time I try to verify my ignite or plunge height my app app crashes. Getting a constant pop up telling me to confirm my torch is installed correctly.
Post by chademling94 » Sun Jan 24, 2021 4:03 am
Just tried the new 4.79 software. Updated fine and table moves around fine (ALOT FASTER) but when I try to bring in a file nothing shows up? It shows the amount of pierces and cut time but doesnt show the drawing on the screen, just says "tap to load file". I know they are good files, I have used them before the update and again after reverting to the old software just to make sure nothing weird happened.
elopez
Post by elopez » Sun Jan 24, 2021 3:18 pm
chademling94 wrote: Sun Jan 24, 2021 4:03 am Just tried the new 4.79 software. Updated fine and table moves around fine (ALOT FASTER) but when I try to bring in a file nothing shows up? It shows the amount of pierces and cut time but doesnt show the drawing on the screen, just says "tap to load file". I know they are good files, I have used them before the update and again after reverting to the old software just to make sure nothing weird happened.
Could you email me the file you're having issues with? eduardo@gofabcnc.com
Post by chademling94 » Sun Jan 24, 2021 5:18 pm
I'm out of the shop today but will right away tomorrow, the file isn't the issue, I've used them multiple times on the old software with no issues but I'll send it anyway just to make sure
elopez
Post by elopez » Sun Jan 24, 2021 7:53 pm
chademling94 wrote: Sun Jan 24, 2021 5:18 pm I'm out of the shop today but will right away tomorrow, the file isn't the issue, I've used them multiple times on the old software with no issues but I'll send it anyway just to make sure
I'm sure the file isn't the issue, but it will allow me to see what part of the code in the app is crashing while opening the file
Post by chademling94 » Tue Jan 26, 2021 12:15 am
Files are sent
