Some cuts
Re: Some cuts
Those look awesome. What are you using to do the backlighting. I have one coming up to backlight so just looking for ideas others have used.
Re: Some cuts
I use a 15 dollar amazon prime led light strip that I cut. It comes in like a 16 ft roll and has a dimmer. Cost 14 dollars. If they are putting signs out under a patio I normally clear silicon over them . It just thin double side tape with LEDs.
Re: Some cuts
Thank you. That sounds like what I was looking at on amazon. Wasn’t sure if that was the answer. And always looking for other ideas that people have made work.
