3/4"
Posted: Tue Dec 04, 2018 1:38 am
by chademling94
Pierces didn't go so hot (actually to hot
) but edge start worked good! I drilled a hole for the center pierce.
Re: 3/4"
Posted: Mon Dec 10, 2018 8:55 am
by GregSmith
Nice! Was this on your 80amp Everlast? What amperage and cutting speed?
Re: 3/4"
Posted: Mon Dec 10, 2018 3:28 pm
by chademling94
Yes 80 amp everlast. Cut at 65 amps and 175 feedrate
Re: 3/4"
Posted: Tue Dec 11, 2018 2:12 pm
by ClifO
That's really clean! Can't wait to get mine.
Re: 3/4"
Posted: Sat Dec 15, 2018 7:51 pm
by GregSmith
I get jitters in 10ga at 50amps 1400mm
16ga jitters at 30amp 750mm and 40a at 1400mm. Having trouble getting clean cuts so can’t do art work until its cleaned up.
Re: 3/4"
Posted: Sat Dec 15, 2018 11:31 pm
by chademling94
The way the torch is clamped is the issue. If you look in the Tips and Tricks section under (Cuts look jagged or sawtooth like) Bdspindles made a fantastic looking clamp which i think is the direction i am going to go. But yes anything over like 400mmpm i get a crazy torch jitter on sudden direction changes.
Re: 3/4"
Posted: Wed Jan 23, 2019 10:08 am
by GregSmith
Wow, I never thought it would be a clamping issue. Looks like I found another project for my cnc mill. Thanks. I’ll post a picture when I get the clamp milked out.
