Amperage remote pendant faulty?!!
Posted: Thu Dec 10, 2020 4:23 pm
by Roman Wright
The remote when plugged in only will read to 63 Amps the highest the knob will go. When the pendant is unplugged the led screen will read up to 79 Amps. The manual says that with the pendant plugged in you can reach higher Amperage. but, this isn't the case the machine reads higher with the pendant unplugged. do I have a faulty pendant? can I just use the led screen to cut to get higher amperage? Any advice would be helpful thank you!
Re: Amperage remote pendant faulty?!!
Posted: Wed Jan 06, 2021 4:37 pm
by Go Fab CNC
Hey Roman,
On the back of the Remote Amperage Box is a tiny Hole that’s used for adjustment.
Use a small Flat Head Screwdriver to rotate the Brass Screw inside Clockwise and Counterclockwise. As you rotate it, you’ll see the new knees on the PowerEdge and the Remote Amperage Box either get further apart or closer together.
Once the numbers match, you’ll be good to go and can reach those higher numbers.
