Post Processor for Go Fab CNC Tables
- Site Admin
The Generic Plasma post processor is compatible with Go Fab CNC Tables.
Re: Post Processor for Go Fab CNC Tables
Loaded this last night. The demo version is fully functional ( limit 180 lines of code) I cut several simple parts with it.
I work with mostly industrial customers and we collaborate in Solidworks and AutoCad. I get files of many parts and need a good nesting oprion as well as
working with .dxf. Sheetcam will notify and delete double lines. I purchased the full version $140 US.
Another cool site is CNC-apps they have online dxf to Gcode, and many other cool tools that work within the webpage. The Fix dxf app is really good.
https://cnc-apps.com
Hi IronTexasFab, just wondering if you happen to have a toolset configuration for the everlast plasma on sheetcam, since i'm new at this don't know how to configurate.
Regards..
Regards..
help!
I am trying to get some .dxf sheetcam cnc files to run today!
When I try to load them into the tablet
"unfortunately GOFAB has stopped" happens and it shuts down, or "can't find pierce points, try to use z axis"
The code in the file looks very simple, here is an simple example, square with a round hole in it.
G20 (Units: Inches)
G90
G40
(Part: sc-2-h)
G00X0.723Y0.615
G01X1.0Y0.501
G03X1.0Y0.501I1.0J1.0
G00X2.0Y2.3
G01X2.0Y2.0
G01X2.0Y0.0
G01X2.0Y-0.0
G01X-0.0Y-0.0
G01X-0.001Y0.0
G01X-0.001Y2.0
G01X-0.0Y2.001
G01X2.0Y2.001
Inkscape files will load, but have too many pierce points, sheet cam lookd like a better techincal program
G20 (Units: Inches)
G90
G40
(Part: sc-2-h)
G00X0.723Y0.615
G01X1.0Y0.501
G00X2.0Y2.3
G01X2.0Y2.0
G01X2.0Y0.0
G01X2.0Y-0.0
G01X-0.0Y-0.0
G01X-0.001Y0.0
G01X-0.001Y2.0
G01X-0.0Y2.001
G01X2.0Y2.001
Have you found a resolution for this problem?
We are having the same problem. We saved our drawing in sheetcam and trying to send it to the gofab table and it does not read it the way i have it set up in sheetcam.
thanks
thanks
HAVE YOU GUYS FOUND A WAY TO FIX THIS PROBLEM HAVING THE SAME PROBLEM USING INKSCAPE AND PROGRAMS IVE BOUGHT ONLINE
- Site Admin
Are y’all running the Accelerated Software?
As far as I know, everyone using SheetCAM uses the Generic Plasma Post Processor Option with success.
