Hand torch
Hand torch
I just bought a hand torch and the people at everlast we’re no help. Do I need to change any settings to use my hand torch?
Re: Hand torch
You shouldn’t need to. The Handheld and CNC Torch are the same design, just a different body. You can leave everything hooked up like you’re using the Table and just swap the Torches and start cutting Handheld.
Re: Hand torch
Awesome! Thanks man. Wasn’t sure if I should disconnect the Cnc port or anything
