Page 2 of 3
Re: Accelerated Version 4.79 and UP Problems
Posted: Wed Jan 27, 2021 3:55 pm
by chademling94
Tried the newest 4.80 again last night and had the same issue. I am still running the original IPRODA tablet that I got with the table 2 years ago, could that possibly be the issue? I restarted it and made sure everything on is up to date as well and no changes.
Posted: Thu Jan 28, 2021 7:26 pm
by Dfoster84
Updated to .81 today. Tried a dry run and the tip drags. Tried to cut a file and the tip drags. Tried to go back to .78 to get my files cut today and it is showing as a corrupt file??
Posted: Sun Jan 31, 2021 2:24 am
by elopez
chademling94 wrote: Tue Jan 26, 2021 12:15 am
Files are sent
Are you still having issues opening the files after current update, because I just opened the files on my tablet without any issues?
Posted: Sun Jan 31, 2021 11:51 pm
by Cody
Just updated my tablet to 4.81 and attempted to use my table today.
Problems:
The "get thc value" on cut settings doesn't save anything when you use it.
My torch is diving/dragging EVERYWHERE now like thc isn't working at all.
App crashes when i try to verify ignite or plunge height.
My files keep saying "could not find pierce point. Try to use z axis?" and does nothing when you select yes, but I know it's not the files because I have 4.78 on my phone just to check the files before I send them to my tablet to cut and they open fine on 4.78.
When I load a file into the app, auto parts discovery is already on. However, when I go to turn it off my files disappear sometimes and only show back up when I turn auto parts discovery back on.
Update:
My phone will open my files perfectly using 4.78 so I decided to revert my tablet back to 4.78 also. After reverting my tablet to 4.78 it still says "could not find pierce points. Try to use z axis?"
Update: I went to the app store and downloaded the app which is 4.80 instead of 4.81 from the website and my tablet is opening all my files normally again. I haven't tried cutting again yet to check the other problems.
Posted: Mon Feb 01, 2021 3:12 pm
by chademling94
elopez wrote: Sun Jan 31, 2021 2:24 am
Files are sent
Yes, with the old IPRODA tablet. I tried it on a new tablet and it would work then so the issue is definitely with my older tablet on my end.
Posted: Tue Feb 02, 2021 3:09 pm
by elopez
chademling94 wrote: Mon Feb 01, 2021 3:12 pm
Files are sent
Which version of Android do you have installed on the tablet?
Posted: Tue Feb 02, 2021 3:14 pm
by chademling94
elopez wrote: Tue Feb 02, 2021 3:09 pm
Android Version 6.0 (newest one available on this tablet) and model T1045HPN if that helps any.
Posted: Tue Feb 02, 2021 4:53 pm
by elopez
Do you have the files directly on your tablet, or are you opening them from google drive?
Posted: Tue Feb 02, 2021 4:56 pm
by Cody
Are y'all just monitoring this problem or have y'all looked into the 5 other people posting problems with 4.79+ on here?
Posted: Tue Feb 02, 2021 5:28 pm
by Go Fab CNC
Cody wrote: Tue Feb 02, 2021 4:56 pm
We’re looking in to any and all problems and fixing them as we go.
We’ve Released:
4.79
4.80
4.81
And intend to Release 4.82 today.
