Accelerated Version 4.79 and UP Problems
Re: Accelerated Version 4.79 and UP Problems
Tried the newest 4.80 again last night and had the same issue. I am still running the original IPRODA tablet that I got with the table 2 years ago, could that possibly be the issue? I restarted it and made sure everything on is up to date as well and no changes.
Updated to .81 today. Tried a dry run and the tip drags. Tried to cut a file and the tip drags. Tried to go back to .78 to get my files cut today and it is showing as a corrupt file??
Are you still having issues opening the files after current update, because I just opened the files on my tablet without any issues?
Just updated my tablet to 4.81 and attempted to use my table today.
Problems:
The "get thc value" on cut settings doesn't save anything when you use it.
My torch is diving/dragging EVERYWHERE now like thc isn't working at all.
App crashes when i try to verify ignite or plunge height.
My files keep saying "could not find pierce point. Try to use z axis?" and does nothing when you select yes, but I know it's not the files because I have 4.78 on my phone just to check the files before I send them to my tablet to cut and they open fine on 4.78.
When I load a file into the app, auto parts discovery is already on. However, when I go to turn it off my files disappear sometimes and only show back up when I turn auto parts discovery back on.
Update:
My phone will open my files perfectly using 4.78 so I decided to revert my tablet back to 4.78 also. After reverting my tablet to 4.78 it still says "could not find pierce points. Try to use z axis?"
Update: I went to the app store and downloaded the app which is 4.80 instead of 4.81 from the website and my tablet is opening all my files normally again. I haven't tried cutting again yet to check the other problems.
Problems:
Update:
Yes, with the old IPRODA tablet. I tried it on a new tablet and it would work then so the issue is definitely with my older tablet on my end.elopez wrote: Sun Jan 31, 2021 2:24 amAre you still having issues opening the files after current update, because I just opened the files on my tablet without any issues?
Which version of Android do you have installed on the tablet?chademling94 wrote: Mon Feb 01, 2021 3:12 pmYes, with the old IPRODA tablet. I tried it on a new tablet and it would work then so the issue is definitely with my older tablet on my end.elopez wrote: Sun Jan 31, 2021 2:24 amAre you still having issues opening the files after current update, because I just opened the files on my tablet without any issues?
Android Version 6.0 (newest one available on this tablet) and model T1045HPN if that helps any.elopez wrote: Tue Feb 02, 2021 3:09 pmWhich version of Android do you have installed on the tablet?chademling94 wrote: Mon Feb 01, 2021 3:12 pmYes, with the old IPRODA tablet. I tried it on a new tablet and it would work then so the issue is definitely with my older tablet on my end.elopez wrote: Sun Jan 31, 2021 2:24 am
Do you have the files directly on your tablet, or are you opening them from google drive?chademling94 wrote: Mon Feb 01, 2021 3:12 pm Android Version 6.0 (newest one available on this tablet) and model T1045HPN if that helps any.
Are y'all just monitoring this problem or have y'all looked into the 5 other people posting problems with 4.79+ on here?
- Site Admin
We’re looking in to any and all problems and fixing them as we go.Cody wrote: Tue Feb 02, 2021 4:56 pm Are y'all just monitoring this problem or have y'all looked into the 5 other people posting problems with 4.79+ on here?
We’ve Released:
4.79
4.80
4.81
And intend to Release 4.82 today.
